I recently purchased a used cedar strip canoe, close to 18' in length. Can't wait to put it in the water. This boat is a considerable upgrade to the majority of my life on water--and I'm very much a newbie to this type of ownership.
It has some scrapes along the bottom (one or two deep enough that they abrade the underlying fiberglass) some hazing in the epoxy coat (I don't know how to describe it except that it looks like white clouding in some areas on the boat), as well as some areas around the keel where the fiberglass didn't bed properly and so is visible. (It looked really good on top of my car, roughed up as it is.)
I'd ideally like to refinish the exterior, but am looking for advice--I've read posts that suggest heat gun and scraper, with sanding when applicable. Ideally, I could get down to the fiberglass, and re-apply epoxy. Has anyone ever had a project like this turn out?
The other option seems to be to try to get back to the original wood. Anyone gotten this far successfully? I've read that this is a considerably more difficult task.
And if I just decide to use it as-is, what would be best to wipe it down with to clean up the exterior? Is there something I can use that will clean it up nicely?
Cheers--thanks in advance--
