Louis Michaud
... and a whole bunch of assembled parts later...
The sail is from a you-sew-sail-kit. Easy to do with the instructions BUT(!!!) I've learned to hate sewing dacron: darn vicious stuff to work!!!!! Next sail is going to be made of flannel...
Follwing the w/c canoe repairability philosophy, most everything is mechanicaly fastened. The only areas I used glue was with the brass bushings for the leeboards/rudder and the mast step sole. I know I went overboard (!!!!) with the complicated drop-in yoke/rudder unit. I wanted a traditionnal yoke with a drop-in unit so I could sail any canoes with the least modifications to the canoes. The drop-in rudder works as it is, better with a coming modification. Aesthetically ? You tell me...
The only modification needed on a canoe is the addition of a mast step sole only 5/8 inches thick. Less work than adding a full mast step to each canoe and is also less obstrusive.
The only problem is with the yoke linkage: the yoke pivot is offset with regards to the rudder "hinges". This has a reduction ( or multiplication ?) effect. Only 4 inches of rope travel are needed to get the full rudder range from one side to the other, steering is a bit hard and not very sensitive. I'll have to make a longer link arm .
Had a lot of fun making the rig and having a great time sailing, along with a few adrenaline rushes: never sailed and have no idea what the heck I'm doing.
The only thing I would maybe change is the sail type: the boom on this standing lug is low (or maybe the mast is too short?) and gets really annoying (Boink!!!) when doing short legs on a narrow lake. Maybe a flannel leg-o-mutton with a sprit-boom...
Best,
Louis Michaud
Rimouski, Quebec
Best,
Louis Michaud
Rimouski, Quebec
