Shadeing And Blending New Planks And Ribs.
michaelrandrews
Can I get some suggestions on the best way to blend the new material so it will match the old. I am trying to achieve a the lightest color possible on the old material.
When you make your planking, get several pieces of raw stock is different colors and shades, then match the new with the old as best you can.
The ribs you're kinda out of luck, unless you have a lot of wood, you get what you get. Then you're in a staining job, and I haven't had much luck there. :(
I suggest you do your repairs before stripping the interior. Spread that gooey mess all around and get the new wood as soiled as possible. Scrape strip and sand the entire canoe uniformly. You can mix and match stain or rack the boat for several years unfinished. This sometimes in not a practical solution but who hasn’t done it? Aniline dye is an excellent choice. You should apply sand and seal first to achieve an even finish.
ANILINE DYES Water SolubleTransparent Stain Powder
The water soluble anilines are best choice for light fastness, transparency of colour, accentuating the wood grain, ease of application, lack of lap marks and use under lacquer and other finishes. They will not leave a muddy surface. For use on new wood surfaces.
These dyes may be finished with varnish, shellac, water based finishes, lacquers, oils or wax.
Each top coat will produce slightly different results in color.
Good Luck
Robert P. Ross
Ross Bros.
PO Box 60277
Florence, MA 01062
413.320.2306
