Rushton Navahoe
samb
Wooden Canoe Maniac
Here is my 1:8 scale model of my Indian Girl Navahoe.
I built it so I had something to do inside the warm house rather than out in the workshop.
I used all the right techniques and most correct materials for a cedar canvas boat except using glue instead of nails and tacks.
MNMt4x9HtdzN9BIflnvujh1KOPa4HcHs4ySy1KWtu_b8uppK1KQP3jIBF2HUR51nmmUHwblBo9BzoUq5O93h3RwP1nyHqKv4x9HJlm6TY_-jRLHKqXuNpUxq9Rllpop9cgZ2eYjI
7o6Iso5zrhz7OPlN_K8rHABaO_f8ehtvcj2_VibCqF1GGJ_ZUOp_JBJt8WyLq1U7qeRmjXK5C4W7O7CCWzBTkSM_kqk_dTFvMFue7mdYayxL6ernPX99I3ciZb9qmIZqhu9O94hC
7t2MvYcV7YIgjE7VI3KKamI0rjgK4G5cWQyYCdD1TKGeYbo1EExUM7zIiJSpEFBY7GBQYtwXaSohHrIqnTzfD7r4NPKV55RhFIt4zEEDci4IBAolddUnDxRcojkYSbpwmZ14SMW1
Be4zk4XzC6AVpwpn90o7HYQYPz6ZadqRMW0k42xZ7fTE5P-lzhCcPNiIfQqpGUWi7h1UZ5IgvgYiN5I_RBoLpdYPWMPkQkHt4aZarZ4nUYZ7mGjYIcCQHWj0YA0L8fP2gI0rr1TN
I’m generally pleased with how things have turned out. There are a couple of things I’d like to change:
The Rushton Indian Girl canoes have quite a bit of tumblehome. I made my form without any tumblehome, thinking I would be able to pull the sides in once it was off the form. I knew this would lessen the rocker and compensated for that. What I didn’t consider was that the length of the rails would be different with and without tumblehome, and that by pulling the boat in, I have caused the sheerline to deform and rise in the middle slightly.
The rails and caps have ended up too chunky. With a finer grained wood, I could probably have cut the curves successfully out of veneer, rather than bending thicker wood. As it is, scaled they would be 2” x 1”
I should have taken more care to make the stems finer. Adding canvas paint and filler has made them far blunter than they should be.
For the ribs and planks I bought veneer. I should have looked to see if I could find or cut some thicker veneer for the ribs. While 0.6mm leaves the scaled planking a bit thick, it leaves the ribs a bit thin.
I0Qfn161u_ObM2Vcs3VDyk_FxXvXSgsI6D6L6KkwE1i2Td5Q25Fs54v0CKtOIH8Wui5EqX3rAn6HsNa45x1k8-Vlnw6x7XU60YhS_FU3VLoJcbgNT6w-E8KyrsoK8ejfDvAnMuch
OgPTpzHSzqLr7YcgxP_ejj13jII1TmdV__kyCI_yaauF1CbbtqGc0DgBpI9Ow4Mdw46HOI2u7EdHplXeDZZvWXX5n_9_IvoElMhva381-Zt_zyaQyJeXQJSXTpdQhW2Kr9qT6yFD
btLKFeRM-xnQgMlshhbNYs9epu1YwZxn5v-PDYAdzrkhOWJAPoqFI3QGvT5DnqqgEp3oMB76jAfETa0-nCWupCKoCIHFl0q3bvSPUYItfoxddeCSv-yuYzv7utZ2Grn3qvbtKIW4
Ghq78tYkHPKkCahOPWEtYFOoLTNVjY7wKFr0mieq60zxQTnQo0eXjtUP7Cp-wvQYsGOjfzO3V7z9C4peF2Y32k9bZ1wsaRsbs9iKiy3fLjplkDi4PP55DL90DZ2RymZSZmSPGLdW
1C7ntUXsOT_0FtsF9OrCXS00L-lEO1hY4UnDaRxOLf3R0nV43ozJLXz18D5MVPmqmDxI-2v4fSMuCJWXrT51vvq78xjyLOqfvAWa8GlftWfn1zH51V-MysaGRVSPIHSJ0zcze7JE
