Longpaddle
Rotten tacks: advice needed
The tacks are no good (see post below on oxidized tacks) after stripping the varnish from the inside and removing the canvas I have determined that the tacks are to far gone, either the head pops off (flakes off) or they break at the bend of the clinch. Not much meat left on the tacks. I am afraid if I left the old tacks in and retacked the old tacks could loose their heads and work through the canvas.
I am thinking that the best course of action would be to remove the planking one piece at a time replace and re tack. There doesn't seem to be a way to remove the tacks other than to remove the planking. The clinched part of the tack will remain imbedded in the inside of the rib, I am thinking I should counter sink these pieces of tack back into the rib and cover them with a drop of epoxy to prevent them from working through the varnish.
Overall canoe is not in bad shape.
18' Otca
Repairs
If it didn't have the tack problem only 2 pieces of planking on the bottom and planking around the stems. No broken ribs
2 stems
2 decks
inwhales and outwhales
canvas
varnish
paint
seats
Longpaddle
18' Otca
Repairs
2 stems
2 decks
canvas
varnish
paint
seats
Longpaddle
