I recanvassed my Yankee last spring using Bill Clement's filler. I'm a complete novice but the results looked pretty good. I let the filler dry for several months over the summer and primed and painted. This Spring I took the canoe out several times and noticed dreaded paint blisters on the bottom. On one excursion, the hull lightly scrapped as I came into shore and a section of paint actually peeled off. When I got home I proceeded to peel large sections of paint off mostly along the keel. Unfortunatly, filler came off with the paint exposing the weave.
I realize now that I put the filler on too thick and it never fully cured. How do I repair this? Should I put on a new layer of filler over the exposed weave? I have been told that new filler will not adhere to cured filler. Any suggestion would be appreciated. Thanks
