greenvilleguy
'42 Yankee OTC
I have 16 to 20 ribs to replace which means pulling a lot of tacks.  Most of the time, I can carefully pull the old tack and tack the new rib using the same hole in the planking covering up the original hole.
Sometimes, however; the original tack will be so well clenched that it is impossible to pull it without leaving a hole in the planking.
Here is my question: Do you guys try and fill those holes or do you just leave them? If you fill them, what do you use?
