Howie
Wooden Canoe Maniac
Some may remember that back in May I posted a Thread about a 15' canoe purported to be a Rushton Indian Girl. I finally have it in my hands - thought I'd post some pics that may help someone provide me with information on what I have. Note questions in bold.
It's 15' long
Stems are 1-5/8" wide at and and extends just past the 5th rib. Nice painter ring & bracket screwed into the front stem. Might ring help ID the canoe?
Decks look like Penn Yans. Are 16" x 7-1/16", steam bent & tapered to meet the stem.
42 ribs, 2" wide tapering to 1" at tips and spaced at about 4" apart. Taper is along one side only. Ribs under decks are also tapered. Rib tips are nailed to side of rail. Note the (about) 30 deg bevel along the thickness of the rib tip that extends to the planking. So what did the outer rail look like? It couldn't have had a rabbet notch. Did outwale have a 30 dev bevel to mate with the beveled rib tip? How thick were they? And I see holes in the upper side of the inner rails that suggest it was once topped with a thin strip of wood. How did rail cap fit with outwale?
Planking is 2" wide except for the 6" wide top-most plank.
Keel is very wide like a Rushton. Is 13' long, 1-7/8" x 1/2" at widest tapering to 7/16". Appears to have been unpainted. Was held in place by slotted c-sink wood screws from every other rib. Note screws not centered on rib but alternating left & right from center.
I think I've run out of picture space. To be continued...
It's 15' long
