Uggg - very frustrated, painting a 47 OT 18' guide. I had major problems getting the filler fair and with priming. The high points are sanded down to the filler (so grey), low points are white primer.
1) Using Kirby's - thinned according to the Mike Elliot book, two cups thinner to gallon of paint. Also added a small amount of Kirby's conditioner. Apparently it is too thin because it is not covering anything very well, can clearly see the the darker areas through the paint, I'm at two coats right now with no sanding. Is it just too thin or do I need to prime it again so everything is white? I suspect the dryness here is wreaking havoc on whatever standard thinner/paint ratio people use. We are currently at 38% humidity which is elevated for the High Plains area.
2) There are a few places where the weave of the canvas is visible in the primer. I had assumed that the paint would cover this but . . . do I need to cover these areas with quick fair?
Think I might grab a beer
Chris
Chris
