I finished my first restoration (a 1964 Old Town Otca 16’), and my son and I took her for her maiden voyage in the Okefenokee Swamp. Two problems developed during the trip:
The first turned out not to be too serious. During the first few minutes in the water, we heard popping and cracking noises. I immediately looked for incoming water as a large alligator along the shore eyed our journey away from the boat ramp. The noise turned out to be the cane seats giving way. Easy enough to fix. The old cane looked fine during the restoration, but turned out to have no strength.
The second problem is more serious. When I took the canoe out of water the second day, the paint in several places along the bottom had blistered. Some blisters were as large as a quarter inch filled with fluid (either dark tea color, or thick and the grey color of the filler). I have several hypotheses on the cause of the problem and would appreciate anyone’s opinion:
1) I didn’t let the paint dry long enough. The last coat went on about 2 weeks before the trip and waited at least 2 days between each of the 3 coats. I always applied coats when the temperature was above 50° F but the temperature at night in the garage often went down into the 40°’s and possibly 30°’s.
2) I didn’t let the filler dry long enough. It was put on at least 4 weeks before the first coat of paint. It seemed dry but the same low temperature conditions existed in the garage at night.
3) I used the wrong type of paint. I used Interlux Brightside Polyurethane Premium Single Part Enamel (4359 White).
4) I should have put down a primer before painting.
I plan to sand down the effected areas which will expose the filler (and lightly sand the rest of the hull), let the hull dry in the now warmer weather for at least a month, and then re-paint. Again, any help would be greatly appreciated.
Well, it’s frustrating not to be able to get the canoe back in the water again, but the whole restoration experience has been a lot of fun. In fact, I was a bit sad that I wasn’t going to be able to go down to the garage and work on the canoe anymore
