OT SN Request
MGC
Scrapmaker
I would appreciate access to the build sheet for OT SN 43871 18.
Thanks in advance,
Mike
The Old Town canoe with serial number 43871 is an 18 foot, CS (Common Sense or middle) grade, HW (Heavy Water) model with red Western cedar planking, closed spruce gunwales, birch decks, birch trim, and a keel. It was built between June and July, 1916. The original exterior paint color was palm greeen. It shipped on August 3rd, 1916 to Center Harbor, New Hampshire. The back side of the card shows that it returned for repairs in 1926 and 1934. Scans showing both sides of this build record can be found by following the links at the thumbnail images attached below.
These scans and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/wcha/ to learn more about the WCHA and http://www.wcha.org/join.php to join.
Benson,
That is the boat. Thank you very much for the prompt reply. I find it interesting that this canoe made it's way back to the factory several times for repairs. It was both used and cared for.
