OT(?) #1852 16
There was a full length bang plate. I dont see any screw holes for an outside stem yet. Hesitant to pull off much of the canvas over the stems due to the condition.
Width of stems are not consistent but about an inch.
That is usually the sign of a canoe that originally had outside stems. The outside edge of a normal stem is commonly closer to the width of the stem band.
Nicely tapered keel to bang plate at both ends.
Seller is trying to get any info from his Dad. My first thought is to hold off opening up the stems to see what is inside and bring it to Assembly for folks to take a look and opine.
There may have been outside stems and significant damage in the past with some sub par repairs.
HI Todd,
Agreed, your canoe certainly could be an early Old Town, and as you suspect it appears to have had some work done to it. The "slant" at the top of each rib is where the rib ends were thinned and tapered to a fine edge for closed gunwale construction. Another way this was done was to let rib ends into the gunwale by cutting a series of rabbets into the gunwale. Closed gunwale Morris canoes are the most commonly seen like this. Old Town and other builders more commonly did what you see in yours when building in the closed gunwale style.
See here for a discussion of Morris rib "pockets": http://forums.wcha.org/index.php?threads/morris-rib-pocket-question.16476/
and here for Rushton: http://forums.wcha.org/index.php?threads/rushton-rib-pockets.18017/
The other closed gunwale canoe in your post #2 above looks like a very original Old Town. Its visible features are what I would expect to see in this canoe if it had not be previously altered. Many features of #1852 appear like Old Town. The thwart behind the bow seat could be original but the stern thwart looks like a later replacement. Early Old Town thwarts looks significantly different from later ones. I don't really know how to describe the difference - older ones are simpler, thinner, and with gentler tapers, somehow more elegant to my eye. If you see them side by side the difference is obvious. Compare the two thwarts on your canoe, and compare the stern thwart here to the ones in your other closed gunwale OT.
The width of the stems suggests outside stems were once there. If the outer face were about 1/4" or so without canvas and 3/8" with canvas, that would indicate no outside stem, but a 3/4" or more outer face suggests an outside stem was there. When you get the canvas off, screw holes will be obviously larger than the holes from the tacks that secured the canvas, and they are larger than ones made for stem band screws.
Those "caps" alongside the decks surely are not original. I've never seen anything like this before and it sure doesn't look up to the standards of early Old Town. The top caps on the outsides of the sponsons are suspect. In my experience, there was a cap only on the outside. I would be these are a later addition. Also, it also looks like there's been some work on the bow stem.
Despite what look like a fair number of changes and some rot/damage, your canoe looks to be in good condition for its age, and you should be able to correct the problems and make it really nice with some time and attention to details.
Hope this helps,
Michael, your comments are very helpful. I anticipate that once I open the canoe up we will find many repairs and that Benson is correct about an outside stem. I do not intend to do much with it for now but as mentioned earlier intend to bring it to Assembly for additional opinions and sharing. Will post a couple of pics tomorrow that clearly show the curved stem from what is likely major damage. My intent is to get a potentially very old canoe close to its former and current glory!
Tell you what, that is a nice thing to learn! I was thinking I have a butchered boat. Still think there are some serious repairs but look forward to many others taking a look this summer to share their thoughts. Really look forward to letting others less experienced than me see these first hand and I look forward to hearing recommendations on how to proceed. Will let you all know what I hear from the folks who passed her down about damage and repair. While I may never get documentation that it is an OT from 1906 it will be informative to see how some early canoes were made and repaired.
