Old town serial number help
Ajreuss
We have an old town that was cut in half to be used as a book case. We have both halves. Serial number shows 0356 a large space and the 16. I believe I am seeing that correctly. We would love to know more about this boat. Thank you in advance!
Welcome, the serial numbers in Old Town canoes and other builders typically didn't start with a leading zero so I suspect that there is at least one missing digit. The suggestions at the link below may help you find it. Please post some pictures of both ends and the serial numbers with the surrounding areas from each end. Thanks,
Old Town canoes didn't have letters in their serial numbers. My guess is that you may have the Old Town canoe with serial number 130356. This is a 16 foot long, AA (or top) grade, Yankee model with open mahogany gunwales, mahogany decks, mahogany thwarts, mahogany seats, half ribs, a keel, and outside stems. It was built between June, 1940 and April, 1941. The original exterior paint color was dark green. It shipped on July 12th, 1941 to Bolton Landing, New York. A scan of this build record can be found below.
It is also possible that you could have another number or manufacturer if this description doesn't match your canoe. Feel free to reply here if you have any other questions. Thanks,
That matches the exact description. What an amazing piece of history. Thank you so much for your help!
AJ
