Old Town 210011, Please reply with info
The Old Town build record for serial number 210011 shows a 17 foot long avocado colored ABS canoe from 1975 that shipped to Oregon. Are you sure that it is fiberglass? Can you provide pictures of the serial number and/or the hull identification number? Thanks,
Thank-you for your reply.
I believe the canoe is 17 foot long.
It is a green color . . . avocado sounds correct.
I bought the canoe in Vancouver, WA . . . across the Columbia River from Portland, OR.
I guess I wrongly assumed it was fiberglass.
It may certainly be ABS as you say.
It is not wood or aluminum.
The canoe is stored about a half hour from home.
I can get the picture you ask for in the next couple of days.
Thanks, again.
-- Mark
Mark, pics are super helpful. not just to ID your canoe but to help others as well. Glad you reached out and look forward to any pics you have!
The Old Town canoe with serial number 210011 is a 17 foot long Chipewyan Tripper model with aluminum inserts in the rails that weighed 78 pounds. It was built in October, 1975. The original exterior color was avocado. It shipped on November 17th, 1975 to Eugene, Oregon. The back side indicates that it was purchased in May, 1976 and moved to Corvallis, Oregon. Scans showing both sides of this build record can be found below.
These scans and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others. A description of the project to preserve these records is available at http://www.wcha.org/catalogs/old-town/records/ if you want more details. I hope that you will donate, join, or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-wcha to learn more about the WCHA and https://www.woodencanoe.org/pricing-plans/join to donate or join.
