Gregory Messier
Loves Wooden Canoes
As many of you know I just completed a rework of a 1910 OT Charles River. One of my most controversial decisions on this hull was to attempt to retain the original blackened varnish inside the hull. I did this for aesthetic reasons (because I loved the way it looked) and also to attempt to retain some of the “story” of this old boat.
One of the major challenges I knew I would face is adhesion of the new varnish. I improvised a process that so far is working well so I thought I would document it here:
1. I patiently hand sanded the inside of the hull with used (dull) 80 grit sand paper in order to knock down high spots, debris in the old varnish, and provide tooth for the new varnish. I completed this step with great care not to cut through the original varnish. The 80 grit worked by far the best as new pieces of 120 or 220 would cut too aggressively and were not equal to the task of knocking down years of accumulated gunk.
2. I thoroughly wiped the inside of the hull multiple times with a rag charged with mineral spirits to remove any oils or contaminants from the surface.
3. In order to hydrate the old dry varnish I then treated the inside of the hull with Tung Oil which did a great job of softening the original varnish. I let the tung oil cure for several weeks as I worked on the outside of the hull.
4. Applied 2 coats of System Three gloss spar varnish 12 hours apart as to avoid sanding between coats. The gloss varnish of course didn’t look great over the original finish but I intended to apply the final coat in satin
5. After the two coats of gloss dried for 48 hours I lightly hand sanded the inside with 220 and wiped with mineral spirits.
6. Applied the show coat of System Three satin spar varnish
So far the finish is holding up nicely with no bubbles. I will update this post with changes if any.
