Roland Thurlow's book uses a 3-1 mix of linseed oil and cuprinol to condition an old canoe before canvassing. I can't find clear cuprinol locally and am curious if I can thin the linseed with mineral spirits, and what other folks are using. Pete
It was copper napthenate. Maybe zinc napthenate in the clear (?).
The simplest solution is to get the mildicide additive from the paint shop. Comes in little packets you squeeze into your finish. It's compatible with oil and water based finishes, so you can add it to your oil if oiling your hull, your filler, and your paint if you want.
Yes.
I went to the mineral sprits because the turp smelled so "bad" (much) and I was working in the house. With low oder mineral sprits, there was very little smell in the house. (and windows for fresh air were also open with fans)
