Linkanoe rib construction
Thanks to those who have already replied. For other readers who have not seen a Linkanoe, it was made in 10 sections that clip together, the outside covered by a watertight skin. This wood laminate that I've called 'ribs' is used along the edges of each of these sections, plus some additional 'ribs'. This wood is made of about 10 laminates, and is about 3/4 x 1 inch. Consequently, about 100 linear feet of this laminate is used to build the Linkanoe. If I was setting up a factory to produce hundreds of boats, as Edwin Link did in ~1945, I'd want to build a machine to crank out this material in long lengths, but cut and bent over forms prior to the adhesive setting. A resorcinol-type glue is a good guess for the adhesive used at this time. I'm curious to know how this wood laminate was built, and bent, at the Link factory, if that information is in an archive somewhere.
I'm seeing some delamination in my canoe, particularly at the corners where there is stress. A couple of the 'ribs' are cracked, but I hope that can be repaired by regluing with epoxy rather than totally replaced.
