There is one main strip that runs all along the center of this boat. that is destroyed. the fiberglass is cracked around it.
check out the pics.
i know i could just slap a patch cloth over the holes after some basic sanding. but the thing will visibly have a gap where no wood can be seen.
what should i do? cut it into a square and add wood in there? then epoxy the cloth on it? or what
the inside piece of wood, not the actual strips, is ok. but its hard to work with cause its pretty much held down with epoxy
check out the pics.
