I've only completed 2 canoes that had top rail caps and skinny side rails, and in the Spring will tackle my 3rd, a Morris. Now that I've done a few I'm smart enough to ask questions...
Should the top cap be installed so that its outer edge is flush with the rail's outer edge?, or might it extend past by a small distance in order to hide the inner edge of the outer rail?
Also, do you tend to install the outer rail first, then the top cap? or vice versa? I'm assuming you'd install the top cap first - then if the top cap lifts a little bit from the rail have a chance of hiding the gap a bit when positioning the side rail.
And also, are screws or nails/brads preferred for securing the side rails?
Just idle questions while waiting for warmer weather...
