Form follows function. If you are going to use the canoe, put it in the water and see if it leaks. If it doesn't leak, don't worry about it. If the cracks bother you, sand the hull with 220 grit wet/dry and repaint. The cracks will come back fairly quickly. If you want to win at a boat show, re-canvas.
