Greenthumbed
Hi all,
I am nearing the completion of a restoration of a ‘72 Chestnut Prospector. I just applied the third coat of paint yesterday evening. On all three coats I have had grit in the finish. I can’t figure out what is causing it.
The paint I am using is:
Home hardware brand Rustoleum.
I am applying it with a foam roller and tipping with foam brush. I changed rollers, brush and paint tray for brand new stuff for this last coat.
After sanding I vacuum the hull and wipe down with a tack cloth.
Now my shop is dusty for sure so on this last coat I painted outside. Same result.
The grit is not everywhere, but is heavy in places.
I am planning on a forth this weekend and would like this problem solved before then.
Has anyone had issues like this and found a solution?
Thanks,
Chad
Thanks,
Chad
