Gaps in Planking
Coanbu
I have just started cleaning out the canoe I pulled out of my parents barn to start fixing it up. It needs the ends fixed up and a few planks but not too much. There are quite a lot of gaps in the planking though. What are the best ways to address this?
Well, the "best" way is to do nothing.
They are not a problem when you put new canvas with filler and paint over the outside.
One of the last canoes I restored suffered from the hands of a wanna-by restorer who felt he had to use plastic wood to fill all the gaps in the planking as well as all the other holes, chips & gouges that the canoe had accumulated. He must have used a putty knife to cram it in, and in doing so he left a thin layer of the stuff all over. It had all turned yellow with age; hard as a rock and ugly as hell. And a bitch to remove. As has been suggested - leave your canoe as it is. Do clean it well though.
I've been restoring a 1913 Old Town Charles River CS that someone covered with fiberglass and filled the gaps with something grey and hard. I removed all the exterior glass and interior varnish, but have not removed the filler between the planks. I'm replacing probably 1/3 to 1/2 of the planking, but the rest still has the filler in the gaps. Should I be digging it all out? Also curious about small gouges from removing tacks in the old planking, from the ribs I replaced, and whether I can get away with filling in the gouges with filler or should I (1) leave it alone or (2) replace that planking as well.
If the stuff between the planking looks bad I'd get rid of what I can. Maybe a heat gun will help loosen or soften it.
Do not fill in outside gouges. First, small divots won't show - they will not show through the canvas and filler. Also if the filler becomes loose it could cause its own problems.
Thanks. The goop between the planks that are left is pretty stable, so I'll go with leaving it. To quote Coanbu above, I do like problems I don't need to fix. Much appreciated.
