I am in the process of repairing/restoring my 16' Huron. My first BTW and very much a learning project. My question concerns the shrinkage gaps between the planking. What would be the best way to deal with these? The gaps range from 2mm (1/16") to 5mm (3/16") and no two planks are free of this space. I will be replacing a couple planks, a gore on one side and a couple others that are badly cupped, so I could make these wider to fill the space but what about all the rest?
Or should I just ignore it as the canoe is in pretty good condition otherwise and has minimal repairs to be done? But as I said, this is a learning project and as much as I would like to get it in the water I still want to take the time to do things correctly on this one and learn all I can for the next.
I understand that over time sand and grit can fall through these gaps and work it's way under the canvas potentually causing problems or if nothing else, unsightly bumps. I've not seen this in my fairly limited exposure to many different canvas canoes but I can see the possibilitiy of such a problem developing.
All comments more than welcome.
