ray levesque
My daughter Michelle and I are moving ahead with our work on the old H. P. Arnold canoe. Progress is slow but at last we can see the light at the end of the tunnel instead of light through the bottom of the canoe.
We have temporarily attached the outside stems and the keel. Now our dilemma is whether or not to fill-in the space between the stems and the canoe’s curved ends to get that “perfect” fit - unfortunately we are not master boat builders. If we decide to fill-in, we have already ruled out using epoxy filler due to probable problems later on if the stems should ever need to be removed. Should we use bedding compound? Would that remain too soft? We intend to paint the stems the same color as the canoe, to hide a few mistakes. Does bedding compound hold paint well enough? If bedding compound is not advisable, what should we use? Plastic wood? Plastic putty? Something else?
We would appreciate any comments on both whether or not the space should be filled and if so what to use to fill it.
With a little luck and an extra long season we’ll christen the canoe this summer.
