Carleton 15227 17
Hi Steve,
Carlton 15222 is a 17 foot regular-grade Carleton model canoe completed June-July 1920. It has red Western cedar planking, spruce gunwales (possibly closed), and maple decks/thwarts/seat frames and a keel. It was originally dark green. It was shipped to Iver Johnson's in Boston, MA, on January 28, 1921.
I know you're a member but will post the usual drill: Image of the scan of this record is attached below-- click on it to get a larger image.
This scan and several hundred thousand others were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others. A description of the project to preserve these records is available athttp://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-the-wcha/ to learn more about the WCHA and http://store.wcha.org/WCHA-New-Membership.html to join.
The Carleton canoe with serial number 15227 is a 17 foot long, regular (or middle) grade, Carleton model with red western cedar planking, closed spruce gunwales, and a keel. It was built between June, 1920 and April, 1921. The original exterior paint color was bright red. It was shipped on April 27th, 1921 to Pike, New Hampshire. A scan showing this build record can be found by following the link at the attached thumbnail image below.
This scan and several hundred thousand others were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will join or renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-the-wcha/ to learn more about the WCHA and http://store.wcha.org/WCHA-New-Membership.html to join.
