Canoe ID Help Please
Gary
Canoe Grampa
Hi folks, I purchased this canoe recently and am puzzled as to its builder? It was to be a chestnut, but its gunwale profiles match a Peterborough? It is 14' long, 33" beam, 13" depth and a modest tumblehome. Seats are babiche laced but could be an add on as they are poorly done. Ribs are 1 1/2" wide with 1 1/2" spacing. It has a shoe keel as well. Inwales were scarfed and have come apart thus the poor shape in the end profile picture. There is a serial number for what its worth 5200 stamped on the stern stem. Any ideas are appreciated.
Gary
The 3rd picture shows a decal on the deck. Is it readable?
Have you stripped the finish off the inner stems enough to see if there are identifying marks stamped there?
And if I were you I'd immediately remove that seat - it seems to too short as the hull profile looks badly distorted.
Hi Howie, seat is gone, first thing I did. I'm going to replace both rails anyway so hope to get the correct shape back. There is nothing on either stem but those numbers mentioned 5200. I was told that the sticker was a Chestnut snowshoe label unfortunately its not readable. I really don't think this is a Chestnut though? The gunwale profiles, the decks all suggest its closer to a Peterborough but I'm no expert? Thanks Gary
Hi Dan, sorry I'm a bit slow, are you suggesting that at some point there was collaboration between these two canoe companies in the building of canoes? As a Canadian that would be really special to have a bit of history from both these legendary companies.
Thanks, Gary
Hi Gary,
Yes, in the 1920s, Chestnut, Peterborough, and Canadian Canoe Company were collected under the holding company Canadian Watercraft Limited. Canvas canoes were built in all three factories, but any of these were known to build for another when demand required it.
Learn more about Peterborough, Chestnut, and CCC.
Also look for a copy of Roger Macgregor's When the Chestnut was in Flower. It's out of print but used copies can be found.
Thanks Dan, very interesting. I am on a waiting list with a used book store I purchase from for the next available copy of that book. I'll do more research with the links provided. Much appreciated, Gary
