Lew's Canoes
Canoe Builder
After 8 or 9 successful new/restoration projects, I thought I was immune from the dreaded paint blisters that I have read about here in the forum. Silly me!!! I am nearly complete with the restoration of a 45 year old Chestnut, and guess what is showing up all over my nice smooth hull and paint job - they look like goose bumps and feel like someone threw a handful of sand into the paint just before I dipped my brush into the can!! HELP!! First I need to understand why this is happening - the sequence of events leading up to now is as follows: Aug 27-sand interior, apply sealer coat of 1/3 varnish, 1/3 mineral spirits, 1/3 linseed oil. Aug 31 - sand exterior and apply coat of warmed linseed oil. Sept 6- canvas. Sept17- apply filler. Nov12 (7+weeks later-canoe cured indoors)- wet sand filler and first oat of paint. Nov 13 - wet sand, second coat of paint. Nov 16 - dry sand, third coat of paint. After outwales and keel...Nov 20 - sand interior and varnish. Nov 22-sand and varnish interior. Nov 26 - sand and varnish. Nov 28-sand and varnish. Initial varnish coat was about 50% cut with MS, final coat only cut about 5%. When I turned the hull over to finish the painting job, there they were! Not everywhere, but several places. So...... I gave the hull another thorough wet sanding and applied coat number 4. Within 2-3 days they were back, and they are still growing. Paint is Benjamin Moore Impervo Alkyld Enamel, with small amount of Penetrol added for brushing. So....... can anyone tell me what is going on here? What is pushing it's way up through the paint - varnish,thinner,linseed oil, filler components, water from wet sanding?? Second question is what are my choices as to what to do about this? Tear off and start over? How about a super sanding right down to the filler level, let the boat sit for a month or so, then repaint? Another approach? Finally, it occurs to me that there may be something in the sequence of my steps that is a contributing factor - perhaps I should have completed all of the interior varnishing before canvasing, filling, painting on the outside. All comments are welcome and greatly appreciated!! There has to be a good lesson here all builders...
