We just had someone bring in another canoe for restoration. This one is covered with fiberglass, although otherwise has all the features of a wood/ canvas canoe.
The question, of course, is whether it was covered with fiberglass when new, or whether this was done at some subsequent date.
The maker of this canoe appears to be Canoe Stelek, Inc., of St. Alexis Des Monts, in what I assume to be Canada. There is a plastic label attached to the stem in the bow with a number: 155711755STK.
The fibreglas cover is still firmly attached, and will probably be very hard to remove,should it be necessary to remove it to restore the canoe to its original condition. Furthermore, the job was well done - if it is original I am inclined not to replace it.
Anyway, here are some questions;
Does anybody recognize this maker, and can you tell me how likely it is that it was originally covered in fiberglass?
Assuming the cover is not original and the owner wants to have it replaced
(and at the risk of stirring up differing views), who has had luck with what methods of removal?
Finally, (wouldn't you know it) there are some broken broken ribs and cracked planking. In order to repair these, I believe I'll have to remove the fiberglass at least in the immediate area to get access to the tack heads. Any better ideas ?
Dave Jackson
Dave Jackson
