Todd_
Thanks for the input. I've just come in from putting the first coat of varnish on the inside of the hull. I can't wait to get it back on the water!
I'd forgotten the aspects of peeling, though doesn't that mostly occur with continued flexing and bending? And the 'bear-barf', well yeah that could be a problem if the fabric gets no chance to breathe. As for cost, what I have found seems to be close to the same range as canvas per yard, and would appear to be more of a one-step application than the filling, sanding and painting required of canvas.
I found a wide variety of fabrics at settlefabrics.com and am mostly considering the following:
200 Denier Heavy Coated F/R Oxford - New!!!
4 oz per sq. yard 200 Denier. This is not your typical, lightly coated nylon oxford; in addition to being flame retardant, it has a super heavy 1-1/2 ounce flame retardant urethane coating! Giving its superior characteristics, this fabric is waterproof and perfect for applications where weight is critical with out moving up to a heavier fabric. Perfect for displays where flame resistance is required!
Uses: Display booths, tarps, ground tarps, tent floors, stuff sacks, light weight bags and much more!
Width: 60"
Colors: Red, Orange, Yellow, Green, Royal, Purple, Maroon, Magenta, White, Silver and Black.
$7.95/yd
I realize I might be pushing for too much weight savings, but I like to experiment and push the limits as far as I can, Given that price point, I figure I can cover the boat for about $55. If I use some neoprene repair tape (double sided) to hold it along the keel and gunwales (about $15) and cover the stems with skid plate material (another 20-30) I've got the boat covered for under $100 with a relatively low labor factor. At worst, if it does fail miserably I can pull it apart and rework the fabric to make a cover for storing the boat. Then I can go back to the 'old reliable' canvas and filler method and paddle away for another 20+ years.
The boat was initially set up with a sailing rig, and the bow seat has the hole for the mast to fit through. I've seen your sail drawings years ago and may get back in touch about setting it up to sail again. I've got a few left over rudders and dagger boards from old Sunfish that may work as parts for this, but not sure how to fashion a mast and gaff rig.
Allen
