b.desmarets
Hey all,
I've just registered on this forum, as I got a week ago, a wooden canoe from a friend, who allowed it to fall into decay.
So, I've started to read articles and watch videos on the internet, about renovation and I realized that, in addition of being something possible, it also looked to be technically reachable in my case...
That's why I'm here, just to evaluate with your help, the magnitude of the work needed, and the level of skills required for it. I've joining here an album of pictures of my canoe. I've tried to put together pictures referring to the same part. I hope you will easily understand about how it is organized and where are the spotted parts.
For sure, you will notice that both bow and stern are seriously damaged. I'm so planning to take off all the mastic (you know, filler), strip the wood, lightly sandpaper and then varnish it back.
However, there is a mastic applied between each strips. So, do you think it is necessary to unscrew all those strips on the side and bottom, take off the mastic, restore them separately and screw them again (isn't there a risk that they change of form?) or a waterproofness test (like putting some water in the canoe and see where there are holes) and detecting gaps between strips when the mastic is all dried is enough?
Also, the inside of the canoe looks in quite good condition, don't you think? I haven't seen any draught proofing with mastic in the inside...
I hope I've been clear (you will notice that my skills in english are limited, even more when it's to talk about canoe...) and that you disapprove the posting of a new thread for my project.
Thanks in advance for your precious help. Till next, b.
