1980's Identification Help
d29315
I am trying to identify this Old Town Canoe and find it's approx. value if any. It's from some time in the 1980's.
There should be a hull identification number on the starboard stern below the rail which can be used to identify it.. It may also have a serial number. The build record may be available if you post those numbers here. The value is likely to be a few hundred dollars. Good luck with the sale,
Is there anyway to know if it is fiber glass or a different material? I don't have the serial number
The serial # should be stamped into the hull material, just below the gunnel, maybe 2 feet in front of the stern.
My guess is that this probably isn't a fiberglass canoe. It looks like Royalex/ABS/Oltonar or their Discovery/Crosslink series.
