125463
Tom Widney
An older gentleman asked me if I could research his canoe for him. He thinks it is an OT and had somebody climb up in the garage rafters to retrive this number. He doesn't know if it has the last two digits specifying the length.
125463 is the number he has.
Tom
Hi Tom,
It should be pretty easy to determine if this is the correct record--
Old Town 125463 is an 18' AA (top) grade HW model canoe that was completed July of 1938 to June 1940. It has open mahogany gunwales and mahogany decks, thwarts, and seat frames. The canoe was also fitted with a keel, outside stems, mast seat and step, a rudder, and a full length bang plate. It was originally dark green, and was shipped to Holyoke, MA, on September 20, 1941. The scan of this record is attached below-- click on it to get a larger image.
This scan and several hundred thousand others were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you and anyone else reading this will join or renew membership in the WCHA so that services like this can continue. See http://www.wcha.org/wcha/ to learn more about the WCHA and http://www.wcha.org/join.php to renew.
Nice canoe!
New home
This canoe was just donated to Camp Widjiwaggan in Ely, where it can be cared for and see some more trail time. It will make the trip from Wisconsin to Ely this spring. Congradulations to Jerry Lusk of Troy Wisconsin for letting her serve again!
Tom
