Many old wooden canoes and boats have a serial number on both inside stems and a decal or tag with the manufacturer's logo on the bow deck. The number is usually stamped on the top of the lower part of the stems. The inside stems are the long curved pieces of wood that form the ends of the canoe. You want to look on the part that extends out from under the decks on the bottom of the floor inside the hull. The serial numbers are stamped in each end of the canoe so check both if a single digit is not clear. These numbers in the stern of boats are occasionally on the edge of the center transom brace, on the edge of the transom itself, or on the keelson.
This is highlighted by the blue boxes in the attached images below. They may be so encrusted with dirt, old varnish, and other junk that the numbers are not easy to read. You might need to use a flashlight at a low angle to get a good shadow, some gentle scraping, or even paper and a crayon to do a rubbing like they do on old grave stones. Another option is to dust the area with chalk or some other light powder and then lightly rub off the excess. Sanding is not a good idea since it is very easy to permanently remove the numbers completely. Rubbing on some varnish remover is usually a much better option.
The most common format is a four to six digit serial number followed by a space and a two digit number which is the length of the canoe in feet. You can post this number in a message at http://forums.wcha.org/forumdisplay.php?f=3 to have a volunteer reply with a copy of the original build record.
Michael Grace has suggested that to get a good read on a serial number:
- clean the stem of dust and debris
- use a low-angle light to get a shadow on the stamped digits
- apply stripper and carefully remove varnish (don't aggressively sand the stem or you risk obliterating the number)
- use pencil and paper to do a rubbing of the serial number.
It has also been pointed out that the digits for ones and sevens along with threes and eights are frequently confused in serial numbers. The image at http://www.wcha.org/forums/index.php?attachments/41135/ may be useful to help distinguish these digits.
The Morris Canoe Company of Veazie, Maine is known to have used brass tags for their serial numbers in a variety of locations including the forward port gunwale, inside stem, and bow seat frame as shown below. There aren't any known build records available for Morris canoes but there is a table at the Wooden Canoe Museum link below with some estimated dates.
The Kennebec Canoe Company of Waterville, Maine is known to have used a broad variety of tags for their serial numbers, stamps on the stems, or both. Some examples are shown below. The early ones had wide stems like a Morris and the later ones had narrow stems like an Old Town. There are also some cases where the number on the tag is different from the number stamped in the wood. The stamped numbers usually match the build records in this case. Some numbers are preceded by an "M" which typically means that the number is in the 100,000 range. The M1572 on the tag shown below matches serial number 101572 in the build records for example.
A modern canoe or boat will have a hull identification number (or HIN) on the starboard stern which can be another challenge. The first three letters are the manufacturer's identification code. These can be researched at https://uscgboating.org/content/manufacturers-identification.php for more details. These codes are occasionally recycled so the "Past Company" may be the one you are seeking. The next five digits are the serial number. Companies using more digits for their serial numbers (like Old Town) will usually omit the most significant digit(s). The last four characters are the date of certification. The format after November 1972 and before November 1, 1984 was Mxxy where xx was a two digit year and y was a month code. The month codes ran in sequence from A for August to L for July. The example shown below is the Old Town canoe (XTC) with serial number 215314 (and 15314 on the HIN) which shipped in January, 1977 as shown on the build record.
The certification date format after August 1, 1984 started with month codes that ran in sequence from A for January to L for December followed by a one dight year of manufacture and a two digit model year. The example below shows an Old Town canoe with the full six digit serial number on the stems and the five digit version on the HIN tag. It shipped in May, 1985 for the 1985 model year as shown in the build record.
HINs that start with a two letter state postal abbreviation followed with a "Z" are reserved for each state to issue. The one shown below was issued by Ohio for a Grumman aluminum canoe that was probably made before 1972 and didn't have an original HIN. It does not appear to have been made for the 1973 model year.
