Shaping the mahogany outwales. After going to all the work to prepare the rabbeted, square-sided outwale blanks I am hesitant to use power tools to shape it. I'm sure a trim router would make the job go faster and if I were doing this for profit, time and efficiency would determine how the job is done. However, I enjoy hand tool work and doing the shaping this way is pleasing to me.
I pencil two lines, top and side, using just my eye and adjust the distance from the square edge with fingertip & pencil point, gradually reducing the dimension as I approach the stems. The rabbet at the stems has already been largely planed off, and both vertical height and overall thickness of the outwales reduced in a gentle taper as the outwales approach the stems.
Pencil lines to work to; a couple of passes with a block plane removes the sharp outside corner. Temporary screws will be replaced and depth refined when canvas, fill, & paint is complete and final installation commences with silicon bronze slotted screws:
Rough round over with a rasp- mine is a long farriers rasp.
Final shaping will use a finer rasp and hand sanding.
Excess outwale material is bolted during this phase, and will be cut off when the stem band is in place.
