Torching....
NOPE X ad infinitum. I couldn't sleep with the image of a square inch of smoldering canvas at 2 am. Lets just say I think the fuzz is good tooth and I sleep great. And when I wet sand I can easily see where I have been. All good. " It's your canoe, do what you want. " doesn't apply here, me thinks.
And same for the oil soaked rags in the old paint can.
I do. When I canvassed my first canoe I read that singeing was the thing to do... so I did and have done since.
Here's a Chestnut Chum freshly cooked and brushed with a stiff bristle brush, then vacuumed. I guess maybe I should re-think it?
No, not in many years. I worry about an edge thread burning up into the canvas, and I found that it simply isn't necessary. After filler cures, there is very little fuzz, and what there may be left is easily sanded off. So NOT singing saves time, is safer, and apparently is unnecessary.
I do not sing the canvas anymore. I did back in the day as recommended in Jerry and Rollin's book but now with the mildew treated canvas I worry about putting fungicide into the air I will be breathing while I'm using the torch. I also worried all night whether I'll have a shop in the morning after using a torch on the canoe in a building filled with wood, other canoes, paint etc. etc.
After 10 of 14 deployments to areas with burn pits I figure I am toast as far as exposure, however I do like to comments about a smoldering thread combusting the shop.
Nope! Years ago I smelled something burning. I thought it was outside. I stepped out to look around and when I turned to go back in the shop I saw ther orange glow coming from my customer's recently singed canvas canoe. A single thread was lit like a candle wick.
As Chris pointed out we still do but I certainly understand all the concerns. The one thing we do is leave plenty of excess material hanging past the inwale so the flame never gets close to the edge. I will say I'm a little surprised with Andre ( who I don't know and have never met) not singeing. It says Firestarter. Wicked Firestarter under his name. Thought he'd be a torcher for sure.
A long time ago, I singed half of a canoe and not the other half. After filling and curing, I could not tell which half had been singed. Granted, when i used to singe the canvas, I once had a wicked fire that I fortunately extinguished before it burnt higher than the outwale would cover.
Hi Mark, good observation. My incendiary proclivities are restricted to those hulls that are pronounced too far gone, and at that after canvas has been removed. Not everything needs to be saved, if this was automotive world i doubt anyone would lavish time and money on a vintage Chrysler K car. I dont see much nap or fuzz on canvas these days, but i will confess to soaking with zinc napthenate which also serves to tighten up once dried, and before filling. Your work looks fantastic btw.
I never have. I learned from Jerry Stelmok years ago at Wooden boat School. I believe in that class we did singe the canvas. That was a long time ago. I also have never wet sanded a paint job. With today's paints I don't see any reason to.
So... I think that's 10 NO's and 2 YES. I'm thinking maybe my torching days are over. The canoe in progress will not get the torch treatment then I'll compare to the others which have been torched. That will certainly alleviate my fears about doing this in an all-wood old barn! Now if I just had a fireproof room for my steambox burner... You'll note that I do have a fire extinguisher close at hand!
Patric, I sort of have the same type of steam set up you do. But I do it outside. Yes even in winter. Only takes another 15 seconds to run back in with a hot piece of wood.
Well, I've never had a fire torching and probably will continue in the future but I have set a steam box on fire before. It was 15 years ago when I was helping McGreivey. I remember saying to Jack " wow, that's really putting out some steam" then I realized it was smoke. Andy brought his box down for us to use as a replacement. Go forward about a half a dozen years and one day Andy showed up at our shop with a new steam box. It's electric! Made of well casing with two heating elements in it. He must have remembered that event. It's not on in the pic but it works great. We call it " The Frankensteamer".
