chris pearson Michigan Canoe Nut Oct 7, 2025 #1 Unfortunately, new inwales etc will be in order. Fiberglass is off, inside just cleanly stripped… Attachments IMG_0531.jpeg 313 KB · Views: 138 IMG_0525.jpeg 342.3 KB · Views: 131 IMG_0521.jpeg 124.1 KB · Views: 141 IMG_0473.jpeg 187.8 KB · Views: 128 IMG_0477.jpeg 340.8 KB · Views: 144
W Worth Gretter LOVES Wooden Canoes Oct 7, 2025 #2 Chris, what is the weird checkerboard pattern on the outside of the hull? Was the fiberglass only attached there instead of everywhere?
Michael Grace Lifetime Member Oct 7, 2025 #3 Wow, Chris - a plaid canoe with the most "interesting" stem band treatment I've ever seen!
Dan Lindberg Ex Wood Hoarder Oct 8, 2025 #4 Is the "checkerboard" a filler to keep the resin from going into the tack holes?
OP OP chris pearson Michigan Canoe Nut Oct 8, 2025 #5 Its led or something else. I presume to not allow seepage of the fiberglass resin. Although I will have to deal with it in the planking seems, Im not sad that they did it before fiberglass! I'm glad this resided out here in Holland, Michigan!
