Dan Lindberg
Ex Wood Hoarder
For those curious about why every doweled seat joint fails, here is an explanation,
(that was posted on another wood based site.)
I'm not sure why or how this may or may not effect a M&T joint but...
For those who haven't read Hoadley's experiments with dowel joints, here is how it works:
The round hole that the dowel goes into has a fixed diameter. It doesn't change size with changes in humidity (at least not measurably). the dowel, however, does change with humidity changes. In times of high humidity, the dowel wants to expand. It is restricted, however, by the hole. As a result the dowel's fibers get crushed against the confines of the hole. Then when there is a time of low humidity, the dowel shrinks. It is now smaller than the hole, and the glue joint fails. It is the same problem that causes axe and hammer handles to become loose. Drive that wedge in deeper, it won't matter. Next winter, just when you want to split wood with it, your axe handle will be loose again without fail.
