Howie
I've just finished using the new ZAR Heavy Duty Strength Paint And Varnish Remover paste. This is the eco friendly stuff. It worked ok - though I found I needed to let it work for 45 to 90 minutes out of the sun. Plus adding more as it worked to ensure the wood was always covered.
I cleaned up afterward with TSP & hot water. But I noted that the ZAR goop looked like it curdled when scrubbed with the TSP solution. That wasn't what I had expected to see. I followed the TSP scrub with a thorough water spray, and it was necessary to use a heavy directed spray to get rid of the curdled stuff.
This 'curdled goop' resction is making me wonder if maybe TSP isn't the best cleanup for this product. The label on the ZAR jug says cleanup is with soap & water. But what kind of soap? There's no 1-800 on the bottle to call....
Anybody use this ZAR stuff before? What did you use to clean up the wood afterwards?
