what model
Hi Carguy,
Old Town 159667 is a 15 foot CS (common sense or middle) grade 50 pound model canoe that was completed March-June of 1953. It was fitted with a keel and painted dark green. Wood species of trim isn't specified, but CS grade is any hardwood except mahogany... generally ash or birch in the 50# model. The canoe was shipped to the Kalispell Lumber Company in Kalispell, Montana, July 1, 1953. The scan of this record is attached below-- click on it to get a larger image.
This scan and several hundred thousand others were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you and anyone else reading this will join or renew membership in the WCHA so that services like this can continue. See http://www.wcha.org/wcha/ to learn more about the WCHA and http://www.wcha.org/join.php to renew.
Hi Kent,
Your canoe is the fifty pound model--- noted on the record as 50#... they are also called "fifty pounders". It's basically an older version of the modern trapper model. Nice size to use either solo or tandem.
