ElectricSquid
Wannabee Canoe Builder
Some duh questions and an outside of the box idea
I'm trying to nail down exactly how I'm going to go about building our canoe.
A few things are certain:
1) it needs to be built for as little as possible (hey, times are tough)
2) I'll be using kiln dried Western Red Cedar (scrap from work, it's what I have, see #1)
I face one issue no matter what style of build I do, the scrap pieces of cedar I can get range in length from 8' to 10' long. I've been reading everywhere on the site about 16' and 18' long strips, but I can't find anything about splicing strips to make up the hull. Um, except the new topic about the guy who made a canoe out of used chopsticks
Which just shows me it is possible.
http://forums.wcha.org/showthread.php?t=3145
Any suggestions on using more than one strip in a row? Splicing strips?
I know to stager the joints well.
Next up is, what's the ideal thickness of a strip for an all wood canoe? What's the thinnest you would use?
... and same question, but for a stripper (wood fiberglass), what's the ideal and thinnest thicknesses to use?
... and here's the weird idea.
Imagine with me for a moment, what if I was to build a 16-17ft long x 30in wide, all wood canoe with the minimum thickness cedar strips and normal thickness ribs (laminated ribs, I'll get to that one later)
After the outer hull strips are all in place, I could spray Great Stuff closed cell foam in between the ribs till it fills the void between them. Wait for the foam to harden, then cut it down to be flush with the inner most edge of the ribs. This is basically the same method we use to insulate and vapor barrier the refrigerated wine cellars I build at my day job.)
One thing I can tell you is that having foam filling the gap between two materials makes for one solid piece or wall. This canoe build idea uses that for all it's worth. (... and it floats)
So back to the build, after the foam is shaped, I'll run thin cedar strips on the inside of the hull (just like the outside). They would be glued to the ribs and the foam, to make the hull solid as a rock.
A couple advantages I can see with this idea are:
The use of less thwarts, more like the way a stripper is designed due to the strength of the fiberglass.
It wouldn't be too terribly heavy due to being able to use thin strips, basically using a half of each strip on each side if the foam, if you can imagine that.
The thinner strips would be a lot easier than full thickness kiln dried strips.
FOAM FLOATS
Oh, and I almost forgot, I'm not going to be able to get ribs to bend the way they need to with the material I have available, so I'm looking toward maybe laminating them up instead. Again, I did site searches on laminated ribs, but didn't find anything (yet)
So, thanks for reading all the way through that. What are your professional opinions?
FOAM FLOATS
