SN lookup 212327 old town
Welcome, the Old Town canoe with serial number 212327 is an 15 foot long Chipewyan model that weighed 60 pounds. It was built in February 1976. The original exterior color was yellow. It shipped on May 9th, 1976 to Whitehall, Pennsylvania. A scan showing this build record can be found below.
This scan and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others. A description of the project to preserve these records is available at http://www.wcha.org/catalogs/old-town/records/ if you want more details. I hope that you will donate, join or renew your membership to the WCHA so that services like this can continue. See https://www.woodencanoe.org/about to learn more about the WCHA and https://www.woodencanoe.org/pricing-plans/join to donate or join.
It is also possible that you could have another number or manufacturer if this description doesn't match the canoe. The hull of this canoe is made from an ABS plastic known as Oltonar or Royalex. It is completely different from either fiberglass or Kevlar. Good luck with the decision,
