Serial number 144889 16
The Old Town canoe with serial number 144889 is a 16 foot long, AA (or top) grade, Yankee model with open mahogany gunwales, mahogany decks, mahogany thwarts, mahogany seats, a keel, and a floor rack. It was built between April and June, 1946. The original exterior paint color was dark green. It shipped on June 18th, 1946 to Lexington, North Carolina. A scan showing this build record can be found by following the link at the attached thumbnail image below.
I wanted to say thank you for the info and share some pictures.
You are most welcome and the pictures are great but they show a double ended rowing boat model and not a Yankee canoe model. Can you provide some pictures showing the serial numbers from each end? A few of the tricks described at http://forums.wcha.org/showthread.php?791 may help if some of the digits are not clear. Good luck,
DOH!!!!! Here is a photo of the serial number 144883 16 Sorry about that.
Hi Craig. The canoe referenced in this thread is something I am researching for a friend. I can try to get better pictures but it might take a bit. I am a complete newb to W/C canoes so I am not much help in answering any questions.
I just finished posting some questions about a Double Ender I am working on when I ran across this thread. looks like the exact same boat. Maybe you can answer some of my questions.
Thanks, Craig
Here is my thread. http://forums.wcha.org/showthread.php?12098-Double-End-OT
The Old Town with serial number 144883 is a 16 foot long, AA (or top) grade, Double End Boat model with open mahogany gunwales, mahogany decks, mahogany thwarts, mahogany seats, a keel, outside stems, a floor rack, and a painter ring. It was built between April and June, 1946. The original exterior paint color was dark green. It was shipped on June 13th, 1946 to Stoddard, New Hampshire. A scan of this build record can be found by following the link at the thumbnail image attached below.
I think it is pretty interesting that these two threads came in so close together today. Both boats are identical and built May, June, and July of 1946. serial #s are 144841 and144883, only 32 boats apart. Cool.
