Serial # help
The Old Town canoe with serial number 149785 is an 18 foot long, CS (common sense or middle) grade, Otca model with red western cedar planking, open spruce gunwales, and a keel. It was built between October, 1947 and May, 1949. The original exterior paint color was dark green. It shipped on June 11th, 1948(?) to Bedford Hills, New York. There was a previous request for a copy of this build record from Bedford Village on August 11th, 1972.
Scans showing both sides of this build record can be found by following the links behind the thumbnail images attached below. These scans and several hundred thousand more were created with substantial grants from the Wooden Canoe Heritage Association (WCHA) and others as you probably know well. A description of the project to preserve these records is available at http://www.wcha.org/ot_records/ if you want more details. I hope that you will renew your membership to the WCHA so that services like this can continue. See http://www.wcha.org/about-the-wcha/ to learn more about the WCHA and http://store.wcha.org/WCHA-New-Membership.html to renew.
