RoadRunner
Hey All -
Been quite some time since I posted - took a fall from the garage attic and dislocated my right shoulder, which put me out of commission for a couple months. Good news is, I managed to miss the canoe when I fell (only by about 3 inches) so clearly I have my priorities straight. Anyway, I've recovered so it's back to work!
I'm at the point where I need to remove all the dried wood glue from the inner hull. Ive been advised to use a paint scraper (rounded the corners of the blade) but I'm finding that it's removing more wood than glue. Take a look at the pics, which show the typical hardened glue pattern on the inner surface. How would you suggest I remove? I'm inclined to use an orbital sander on the flat areas, and wrap sanding paper around an old 2 liter bottle, and forego the paint scraper all together. Thoughts?
