Sanding between ribs
Denis M. Kallery
Passed Away July 3, 2012
In Memoriam
Tonight We went to Menards (read home depot, lowes or whatever). I picked up a Dremel contour sander 6000-01. It has 10 sanding contours, several of which may work just dandy between the ribs. Obviously I haven't tried it yet but it sure looks like it has potential. Anybody tried one? If so how'd it work?
Thanks, Denis
No, but this works great. Sand-O-flex. Got mine at Lee Valley.
Douglas, what type of boat is that? I noticed the double holes for the keel (w/ alternating screw placement?) - different than my OTC... seems like it would have a crazy-wide keel.
RE sanding - I used a hand Black and Decker sander for the ribs, planks by hand. Never used a Dremel, although it sounds like it might save you quite a bit of work.
My sander
Here are some pics of the sander I modified for that kind of sanding. I glued outfitting foam pads to the bottom.
Al
Well Chris,
Kathy sold her house so now the corner in fact the whole North end except where the ladder to the second floor is; I was going to put the furnace in is full of stuff from her house ---so it will have to wait till spring. :(:(
Denis
Denis/Kathy,
Congates on the sale, now you can get more toys (projects) :).
Al,
Thanks for posting, that's close to what I tried, except I only had 1 pad and it was wood with a rubber surface glued on. I used self-stick sand paper cut to size. I suspect the double foam pads would work better.
good idea!
Al
i may have to borrow this idea. i have been trying to figure out a non-manual way to do all on my sanding!
