I've searched the forums and haven't found any info on this topic and have found conflicting opinions in other, more general forums.
I have a Nissan Titan Crew Cap pickup with a cab-high camper shell on the bed. Is it OK to transport a canoe on racks so that the rear rack bar is mounted on the camper shell and the forward rack bar is mounted on the cab? In my online searching I've found some that say no, there's too much movement between the cab and bed and others that say it's OK. My canoe will have to be more or less centered on the truck in order for the prow and stern to be able to hang down and not hit either the top of the cab or the shell. I'm concerned that, if I use two bars on the shell, the canoe won't be centered on the rack and will cantilever out too far over the cab to be secure.
In the past, when hauling my 14' fiberglass kayak, I've mounted it to bars on the shell and used an inflatable rack on the cab in order to allow for some flex. Would this be the best way to haul the canoe?
http://www.maloneautoracks.com/handirack.php
I know that I could install a ladder rack that would fit over the shell and cantilever over the cab but I'd like to avoid doing so.
