WD-40 ain't nothin' like PB Blaster . The difference is like lemon juice compared to 2 molar Nitric Acid. This stuff loosens bolts exposed to years of Michigan's winter roads. If the wood has grabbed the bolt, as it usually does, you shouldn't need a hack saw.
We use PB to take the large nuts and bolts off of coke oven doors. It's the only thing that works, it saves us from burning these nuts and bolts off the door - Republic Steel Corp. / Cleveland, OH
WD-40 stands for Water Displacement, 40th formula. The inventor was attempting to concoct a formula to prevent corrosion, by displacing the standing water that promotes it. In the process, he arrived at a successful formula on his 40th attempt.
WD-40's main ingredients, according to U.S. Material Safety Data Sheet information, are:
* 50%: Stoddard solvent (i.e., mineral spirits -- somewhat similar to kerosene)
* 25%: Liquefied petroleum gas (presumably as a propellant; carbon dioxide is now used instead to reduce WD-40's considerable flammability)
* 15+%: Mineral oil (light lubricating oil)
* 10-%: Inert ingredients
