Hey everybody, awhile back I posted with photos of an old duck boat I found. Now I'm well into the project, and have a few pressing questions. This isn't a "restoration", because I'm remaking it as a wood epoxy boat. My apologies to the purists, but it was never a good boat. And since it was a homemade boat, my conscience is clear. (If it had any historic significance, I would have much more respect for it.)
First of all, the boat is a cedar strip, edge nailed, and it's modern enough that the builder used an orbital sander. It's clearly a home built design, and it was never a good boat. The edge nailing of the strips split several of them down the middle, and it based on the paint in the cracks, I believe these strips split while the boat was being built... I think that explains why it was in fairly good condition.
I'll get some photos up, but the immediate questions are about material for ribs and inside stem. The ribs where white oak, and they dry rotted. I'm replacing them, but more for aesthetics than for structural integrity, since I'm planning on glassing this boat inside and out. I'd like a light colored wood that contrasts with the old red cedar strips. I've thought of ash, or white birth; I don't have any experience replacing ribs, so any thoughts will be appreciated.
Second question--the inside stem. Originally it was white oak, and it cracked; is it going to matter what I use to replace it? Bending a piece like this is new territory for me, because in the past I've only steamed strips of cedar for stems, and that was several thin strips glued together. This will be a much bigger piece of wood, so I'll need to build a "real" steam box...
I'm attaching a photo of the boat as I found it. Hopefully that will help explain what's going on here.
