lastbestplaces@hotmail.co
Help. New to the forum. Bought a 1939 Old Town HW CS recently in NH from WCHA member Dan Kemp...(thanks Dan for your stewardship). Just arrived here at my NM home. It has its original finish which I want to retain where possible. It shows the honest wear of 8 decades and I don't want the canoe to look too "slick", too new. The varnish has "alligatored", the canvas as well. There are minor patches of bare wood on the gunwales. The dilemma - what the hell to do and keep the old lady as original as possible. The canoe is currently on display (Northwoods in the Southwest) at our local museum. That said, it will be used several times per year on Eagle Nest Lake for museum educational and fund raising purposes. I have read volumes on restoration, preservation. Do this, don't do that, confusing to say the least. As I said, I do not want restoration, rather, stabilization and preservation. I have not had the canoe in the water (9000', winter, Rockies, ice). Dan advises a relatively minor leak. The canoe has a keel. I hope to achieve a balance between use and preservation but need help to determine where to compromise, hopefully the "do no (permanent) harm" philosophy...
Here is the distillation of how I think I need to proceed.
First, I have brushed, vacuumed and cleaned all surfaces with distilled water.
HULL -
As to the minor leak, clean and sand the keel focusing attention on the keel/hull joint, then apply several coats of a clear shellac/lacquer thinner 2# cut (re:Mike Elliott <lacquer thinner, as opposed to alcohol cut, will not cloud/turn milky>) to all of the cracked/alligatored canvas. Apply two applications of DAP Dynaflex 230 Acrylic/Latex (from forum) into the keel/hull gap, and follow with a couple of coats of Rustoleum Semi-gloss Hunter Green oil-base enamel (close match) to the keel/hull joint. There are a couple of keel screws that run from the keel into the stem from the outside, I will use DAP on those as well (do not want to tamper with keel screws running from inside...at this point anyway). Unless necessary, do not want to paint the whole hull, hoping the shellac mix will be a better penetrant in fixing the minor leak. Trust the above will result in a watertight hull, if not, additional coats of shellac?
INTERIOR
Have cleaned with distilled water. What is the best next cleaning step - mineral spirits/paint thinner, lacquer thinner, naptha? After cleaning, to stabilize/preserve the look of the varnish, is the shellac/lacquer thinner cut (as above) the best approach?
Thanks, Jack
HULL -
INTERIOR
Thanks, Jack
