Morris c.1915, yes... and that orientation of the serial number plate is seen from about 1912-1916... one factory-worker's personal "stamp"!
If a Morris canoe has a low serial number (genuinely low and not as this one was) and the number is on a rectangular plate with clipped corners that is on the stem, then it's a Veazie Canoe Company canoe-- or a factory-direct Morris, possibly trimmed in hardwood other than mahogany (rather like CS grade, but the buyer could opt for mahogany trim). If the real number was 241 we could have suspected it was a Veazie and been able to put it in the c. 1912-1916 range because of the orientation of the plate.
Veazies in the teens usually have the curved Morris deck... early Veazies (1905-1911-ish) have the curved deck with the extra 'keyhole" cut out. There is one suspected Veazie with a heart deck though. They may have used what was available. I've seen two Veazies with mahogany decks, maple thwarts and seat frames and spruce rails that were all stained the mahogany color... both had low serial numbers on the stem.
Anyway-- this canoe appears to be a full-fledged BN Morris... I just wanted everyone to know that very low serial numbers exist on both the BN Morris and Veazie canoes-- the lowest are two-digit but I'm assuming there were lower numbers that that... and then there are the ones with no s/n plate.
The open gunwale on a BN Morris with a low s/n would be odd as MGC says, as the open gunwale didn't come into being until about 1905... so if 241 had been the number, there'd be another reason to suspect it was a Veazie and not a BN Morris.
And a Veazie IS a Morris... it's just Bert and Charlie's way of offering a second-grade canoe while maintaining that all BN Morris canoes are first-grade... and by-passing the dealerships.
